I need this footprint for a 10pin rotary switch that I can’t find in the CORE parts database.
Can anybody help me please?
Regards,
Gregory
Regards,
Gregory
You would need to indicate which exact model you want. There are at least 2 (1 pole or 2 pole) which have different schematic layouts.
My bad
I need the 1 pole to be precise please
This should do what you want. The pin numbers may not be correct as the data sheet isn’t clear. As always before ordering boards, print out the pcb footprint at 1:1 scale and check it (and in this case the pin numbers!) against a real part.
alpha-sr1712f-rotary-switch-1-pole.fzpz (9.1 KB)
I will check
Thanks for the effort
