Would anyone be able to point me to a 1 pole, 4 position rotary switch library file please?
Thanks in advance
Thanks in advance
Same answer as the other request a google search for “fritzing part rotary switch” turns up the available parts (none of which are 1 pole 4 position, so there doesn’t appear to be a part.) In order to make a part you would need to fill in the data requested in the template that you appear to have deleted.
