HI, pretty new on making new components and I’m in need of a model of a 1.54" I2C oled display that I bought on AliExpress OLED, basically what I need is the PCB layout because the display is part of a PCB that is going in a tight place and needs to be as close as possible to the exact measurements
Thank in advance for any help.
This part should do what you want. Note as usual if you want mounting holes (which are only in silkscreen) you need to drag a hole from pcb in core parts in to the sketch place it over the hole in silkscreen and set the size appropriately.
oled-display-1_54in-4pin.fzpz (4.0 KB)
Thank you so much, it is exactly what I need.
