Not able to install 0.9.6 on Windows 10 Pro (19042.1052). Hoping I’m not paying for nothing. Has anyone else experienced this issue? What’re the possible solutions?
Haven’t seen or heard of this error before, but here is something to try. As you haven’t installed yet you should be able to just delete these two directories and Fritzing will recreate them. This however isn’t the typical error caused by this fault so it may not help.
I gather that you are running the installer from the gui (double click from file explorer). If you can run from a text (cmd) window instead, more information could be shown that tells more about what the problem is.
Thanks for the suggestion. I tried but it doesn’t seem to be the issue.
Thanks for your suggestion. I have finally identified the problem…which is my antivirus software.
