Wont Load Custom SVG That Uses OCRA Font
Made an SVG in illustrator using the provided OCRA font, loaded it into parts editor, says it only supports OCRA and defaults the parts text to Ariel, opening the templates provided by yourselves using the fonts provided also throws an error in illustrator using the OCRA font, seems theres a fundamental issue here…I can upload an SVG so you can open it with a text editor and look if theres support for that on the forum?
loaded up fine…
latest, mac and windows both throw same error
While svgs are supposed to be supported I don’t think they work. The work around is to rename the .svg to .fzpz (you may need to zip the .svg and rename the zip to fzpz if the forum objects to a raw svg) and tell us that the fzpz is really an svg.
