Trimpot - 3362P
Evidently there are lots of 3362s with different pin arrangements.
Datasheet - https://www.bourns.com/docs/Product-Datasheets/3362.pdf
v1 - Trimpot 3362P - Trimpot 3362P.fzpz (10.0 KB)
Looks good, the only thing the script found to bitch about (other than reference files which are essentially meaningless :slight_smile: ) is the view box is in px:
$ ./FritzingCheckPart.py …/imported_parts/‘Trimpot 3362P’/‘part.Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1.fzp’
File
’…/imported_parts/Trimpot 3362P/part.Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 36
Modified 4: File
’…/imported_parts/Trimpot 3362P/svg.breadboard.Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_breadboard.svg.bak’
At line 4
ReferenceFile
‘trimpot_3362P_breadboard.svg’
doesn’t match input file
‘Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_breadboard.svg’
Corrected
Modified 4: File
’…/imported_parts/Trimpot 3362P/svg.schematic.Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_schematic.svg.bak’
At line 5
ReferenceFile
‘sparkfun-electromechanical_trimpot-1_schematic.svg’
‘Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_schematic.svg’
Corrected
Modified 4: File
’…/imported_parts/Trimpot 3362P/svg.pcb.Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_pcb.svg.bak’
At line 4
ReferenceFile
‘trimpot_3362P-2_pcb.svg’
‘Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1_pcb.svg’
Corrected
Warning 6: File
At line 2
ReferenceFile name
‘sparkfun-electromechanical-trimpot-trimpot_pth_s3_lock.fzp’
Doesn’t match fzp filename
‘Trimpot 3362P_49a222587dd2f634f9e4a0a33b187e7f_1.fzp’
Warning 19: File
At line 2
Height 20.48085 is defined in px
in or mm is a better option (px can cause scaling problems!)
Warning 19: File
At line 2
Width 22.176001 is defined in px
Sorry I’m not smart enough to run your program, and I’m too lazy to do more than do the simple mod other svgs.
