Hello guys, most of you have had one problem after extracting and installing fritzing with the next message “error api-ms-win-crt-runtime-l1-1-0.dll” Well, it happened the same to me, the only possible solution that I thought at the moment was to download the .dll file but then after downloading and extracting the .dll file I found that when you try to run the program again it gives you another message but with a different .dll file.
The point is that I downloaded every single .dll file and it actually worked.
If you want to try here is the link to get my .zip file containing all the necessary .dll files that i needed, I hope it can help you.
LINK___ https://mega.nz/#!Et1y2SgL!rmHslipct9SWotWqMuEbmdiCJ8F4bN-FSMNeG6yi-xs
It was tested out in a computer with Windows 7 Ultimate 32Bits
