A rectangle load cell or weighting sensor with four wires coming out: Red, white, black, and green. This is based on a load cell from Sourcingmap (5 kg).
It works well for the breadboard view, but is not a PCB part.
Rectangle Load Cell.fzpz (6.7 KB)
Hi! thanks a lot for the part! Is there a reason that you chose the order of the wire-colors that way?
Aren’t the sensors usually connected in this order: red, black, green, white? (e+,e-,a-,a+)
For no particular reason, other than that my physical load cell had the wires come out in that order. I have only one, so that could easily have been an unusual configuration.
