I’ve been working on a project that encompasses the following parts,
- PaPiRus 2" screen, RPi Zero v1.3, Adafruit Powerbooster 1000c and a 1200 mAh battery.
I is a bit of a thick bundle and I’m looking for a case to hold all of the components.
I was hoping that this knowledgeable group of people here might be able to steer me in the correct direction.
The question is, how can I/do I go from the physical being to a 3D (.stl) files to print out a case. I realize I probably need some software. I do have OpenSCAD installed, but I don’t have a 3D scanner to use.
Is there a way to import the dimensions of the boards into a software program to try and build something?
Any questions welcomed.
Thanks
Scott
