Part Request - IL612-2e Digital Isolator
I need the above Digital Isolator in a project to isolate the USB output of my Feeltech FY3224S Function Generator.
The part is manufactured by NVE Corporation. Here is the Data Sheet: https://www.nve.com/Downloads/il600.pdf
Credit to SDG Electronics for the design and explanation on YouTube.
Thank you very much.
What package?
If it’s a std DIP you just grab one and give it the part number.
#3
Thank you for the response Old_Grey.
Dip8.
I took a 555 and changed the pinouts. That worked OK, but for some or other reason, the numbering was changed to 1, 2, 3 ,4, 7, 8, 5, 6.
I worked around that as well and I now have a PCB.
May you have a wonderful 2018.
#4
Or you could use this:
IL612-2e.fzpz (8.0 KB)
although nothing much except schematic will change.
