the part can now be found here https://github.com/mathijswesterhof/Fritzing-parts . please test it first for me since i have no part available. print it on a blank paper and see if it fits the manual was not that clear with all dimentions
Perfecto, just tested it and it prints the correct size and the part matches the holes!!!
If you want something FREE from Wusik com just let me know.
Cheers, WilliamK
Oops, looks like this other relay is also not included with the regular parts. I don’t want to push my luck, but could you also give me a hand with this one, pretty please?
From the looks of it, it should work on my car, as it can support up to 14,4 Volts, but I don’t know, maybe I will use a shotkie diode on the coil to drop the voltage just a bit, as it also supports 75% load to close, so it should work. From my tests my car doesn’t go above 15V anyway…
im working on it now but i encountered some problems with the pin offset. can you please confirm that this is the right pin offset and width then i can finish the part https://github.com/mathijswesterhof/Fritzing-parts (copper.svg and copper.pdf)
