Necesito el relay de arduino
Hola amigos, necesito el relay de arduino para un proyecto y no logro ubicarlo, me pueden ayudar?
Gracias.
Tienes alguna referencia o imagen del mismo? Porque en internet hay un montón.
#3
You need to search Google for the part, and if you can’t find it you have to post a link to the exact datasheet.
Debe buscar en Google la pieza y, si no puede encontrarla, debe publicar un enlace a la hoja de datos exacta.
#4
As @KingDarBoja said there are lots available: some suggestions:
type relay in to the fritzing parts search box and press enter (the search box is the magnifying glass in the parts bin). A number of different relays in core parts come up.
Search here in the forums. A number of different types or relays have been posted in parts submit that have not made it in to core parts yet.
if you need a specific model of relay try a google search with the search term “fritzing part relay_model” (where relay model is replaced by the part number of the relay you want).
