Measure distance between two pins
Is there a way to measure the exact distance between two pins on the layout?
I would need it because the cutout for the display is given, and I need to do the pcb matching to it.
Thanks for all help!
#3
At the very bottom of the core parts bin you will find a ruler that you can drag out onto the PCB. One edge has extremely fine resolution. You can also change the length and units in the inspector on the right.
