I’m trying to add a new part.
I’ve created part with adobe illustrator. if i add the svg image to the shematic in parts editor all looks fine.
After adding it to the shematic to create a circuit it only shows me a big red recktangle.
If i look on it on firefox or inkscape all looks good. What i’m doing wrong. Is there a documentation how to create a part correctly because the documentation won’t help me.
I’ve attached the svg’s i’m using
After the svg is added to FZ by Edit part, you have to assign the pins. Click the pin in the right hand box in FZ edit , press select graphic, click on the pin in the drawing, and the pick N,S,E,W in needed, and the save.
