Isolated circle around VIA
hello communitiy,
I made a metal core PCB for a strong LED lamp… I made some VIA’s to connect top and bottom side. I have copperfilling top and bottom side (GND) and the VIA points are isolated, how i can remove the isolation circle around VIA?
Thanks for help…
Bernd
Bernd,
If you right click on the VIA and select ground fill seed. Then copper fill ground. OR fill the area then drag in that VIA for placement after filling the board. Either way should work.
#3
thanks! it works…
Bernd
#4
Great to hear! have fun! :+1:
