Try this and see if it does what you want.
AZ832P2-2C-5DE_Latching_relay.fzpz (8.4 KB)
Of note, the hole sizes in PCB are set to 0.39 as their datasheet suggests as well I put in all the pins so you can use a 16 pin socket if you wish. If you don’t want the extra holes just delete them, as they are set noconn and thus Fritzing won’t notice their absence. All three views are present and appear to work as far as Fritzing is concerned (in the real world who knows yet
(Edit:) And here are the other 2 as well:
RT314F05_Latching_relay.fzpz (10.4 KB)
RT424F05_Latching_relay.fzpz (9.7 KB)
