I made PHP viewer for fritzing but
Hello, i made a Fritzing.class.php file in order to have a viewer for a fzz in svg format.
Everything work like a charm but i’ve some problem with rotations of components.
Instances rotations seem to be defined in the attributes of
instance->views->breadboardView->geometry->transform
node but the format of it is a mystery for me, i see 9 parameters like
m11="0.707107" m12="0.707107" m13="0" m21="-0.707107" m22="0.707107" m23="0" m31="15.9403" m32="-2.45825" m33="1"
for a simple 45° rotation, so far I have deduced by myself the logic of xml but on this data format, i’m lost …
Any ideas ?
I would create a new fritzing sketch and only put one part on the board and set its location to 0, 0 in the inspector and do not rotate it. Then save the sketch and open it in your editor and take note of the numbers. Then I would open the sketch again and turn the part once (45 degrees), save and re-check in the editor and take note of the numbers again. After that I would try moving the part a specified amount using the inspector and again after saving check it in your editor. You should be able to tell what changes take place for each type of move.
#3
While I’d probably try Sublimeartistry’s suggestion first, if you want the technical explaination you are looking for transform matrixes in the svg spec. I think that the various editors use different ones and I don’t know what Fritzing does (which is why trying it on Fritzing output is the best bet.)
Thanks for your responses.
I’v already tried this manipulation, for 0 0 0 (x,y,r) i’ve a geometry with
<geometry z="2.5" x="-0.3095" y="0.4595"/>
And no transform subnode (because no rotation)
with a rotation of 45° a transform node appear with
<transform m11="0.707107" m12="0.707107" m13="0" m21="-0.707107" m22="0.707107" m23="0" m31="8.74625" m32="-12.3763" m33="1"/>
It seem position (geometry attirbute) and rotation (transform attributes) are not linked, and position work well in my wiewer, that’s just the transform attributes which are incomprehensible for me, if it’s a transformation matrix there should be only 6 parameters and not 9 ?
#5
I thought i’m understanding something.
math matrix is actually composed of 9 parameters but only 6 are useful in our case :
It seem that m13,m23 and m33 are thoses useless 3 coordinate, i’ll try to transpose other m11,m12,m21,m22,m31,m32 to the 6 parameter of svg matrix.
#6
It works ! I’ve probably the first web fritzing projet viewer, thanks for your emulation ! :slight_smile:
