How to report a bug / issue
If you have a problem with Fritzing, please first do a search if it has already been reported here or in our github issue tracker. In that case add your additional insights there.
If nobody has reported your issue before, please try to describe it as precisely as possible. A good problem report contains:
  • Steps you took that resulted in the problem
  • What you expected should have happened instead
  • Your version of Fritzing and your operating system
  • Any files that relate to this problem: sketches, parts, log files or screenshots
If you have some technical knowledge, please report your issue on github, not here.
This will make it much easier for developers to solve your issue, thanks!
#3
