It’s an absolute pressure sensor for $5 from China, so someone might find it useful.
Full part. Can be PCB mounted with difficulty - the plug shroud fouls the PCB so it has to be spaced -.
V1.0 - GM-MAP.fzpz (490.7 KB)
GM MAP sensor with plug shroud cut off and pins bent sharply at 90º - can be PCB mounted easily -.
V1.0 - GM-MAP-cut.fzpz (180.5 KB)
