Fritzing window sizing on ubuntu 16.10 issue
pulled the correct arch of the linux fritzing, extracted and ran the Fritzing executable. application loads but looks 2x the scaling on my 1080 resolution
the window would be full screen to my resolution not larger than the screen.
16.10 ubuntu
3.20.4 gnome-shell
0.9.3b of Fritzing
DEBUG
reck7@T450s:~/apps/fritzing-0.9.3b.linux.AMD64$ ./Fritzing -d
"translation en_US loaded 1 from /home/reck7/apps/fritzing-0.9.3b.linux.AMD64/translations"
“registering font family: Droid Sans DroidSans”
“registering font family: OCRA OCRA”
“got transaction”
“referenceModel::loadAll completed”
“parts count 2029"
qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
"load something”
“checking for backups”
"check files to load 0"
“create empty sketch"
libpng warning: iCCP: known incorrect sRGB profile
"loading bin ‘Core Parts’”
“module id mystery_part_sip_3_100mil not found in database”
“module id generic_ic_dip_8_300mil not found in database”
“module id generic_female_pin_header_2_100mil not found in database”
“module id generic_shrouded_pin_header_10_100mil not found in database”
“module Mystery Part - 3 pins:mystery_part_sip_3_100mil obsolete svg /home/reck7/apps/fritzing-0.9.3b.linux.AMD64/fritzing-parts/svg/obsolete/icon/mystery_part_icon.svg”
“module Generic female header - 2 pins:generic_female_pin_header_2_100mil obsolete svg /home/reck7/apps/fritzing-0.9.3b.linux.AMD64/fritzing-parts/svg/obsolete/icon/generic_female_header.svg”
“Setting platform to Arduino”
“Setting board to Arduino UNO”
"Setting port to "
"adding layer kin 57511 3 25 bb96c70"
"adding layer kin 57512 3 18 2b6a810"
“finish up sketch loading”
"http://fritzing.org/download/feed/atom/linux-64bit/?version=0.9.3b.04.19.5c895d327c44a3114e5fcc9d8260daf0cbb52806&sysname=Ubuntu&kernname=Linux&kernversion=4.8.0-27-generic&arch=x86_64&sysversion=16.10&pid=76c07cd5aeb7012738587d696dbf0866"
“http check new version”
“http check new version no error”
