I am using an old OS X V 10.7 on my Mac because I do not want my other external hardware to be incompatible with newer operating systems. Anyway, when I connect to the WiFi network at work, I find that when I fire up Fritzing, it crashes and brings up a message “This program has quit unexpectedly”. When I disconnect from WiFi and launch Fritzing again, it works fine.
Also, if Fritzing is left “open” for a long time, it seems to interfere with other applications and when I try closing it, it can’t close and I have to “Force Quit” the application.
Fritzing should work when I connect to the WiFi network and use it for commercial use. However, when I connect to the Wifi network after Fritzing has launched correctly, it continues to work. I use Fritzing alongside Eagle which is essential for my job, so it would be really nice if Fritzing works flawlessly please.
Newest version of Fritzing v0.6.3 beta, and Mac Os V10.7.5
