Fritzing fails to export stripboards correctly
I used the Radio Shack stripboard, then File > Export > as Image > svg
The vertical lines are too thin, much thinner than the pinhole diameter. Also, inside the pinholes, some solid stuffs occur.
Fritzing 0.9.3.b
Linux Mint 17.3
