I have a part, an A3144 hall effect sensor, that works well in schematic view, but in PCB view, the through hole connectors are touching each other, causing overlap in the design rule check. Any idea how I could edit this part to space the connectors a bit more?
That isn’t the hole part. It needs to be the .fzpz file (which is the .fzp and the associated svgs) to fix it.
the part here looks to be correct.
