Fritzing 64Bit on Ubuntu 19.04 libssl error - program wouldn't start (Solved)
I fixed the problem manually, just writing my process down in case anyone else has the same problem.
I downloaded the Ubuntu bit archive from Fritzing website, extracted to my local and ran ./Install and ./Fritzing
The error was “error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory”
Fritzing normal startup
Fritzing 09b from Fritzing website
Ubuntu Studio 19.04
Don’t worry I fixed it!
So I got the missing libssl from Debian repo here: https://packages.debian.org/jessie/amd64/libssl1.0.0/download
Edit: run dpkg --install filename.deb after downloading it
It was not available through apt on Ubuntu 19.04 - I believe they have replaced this library with a newer one (most likely almost exactly the same thing with a new version number, so you could probably link it up)
If I am incorrect in my assumptions here please correct me. Anyway Fritzing is up and running again for me at least.
I’d say as long as it works your assumptions are fine :slight_smile: . that said it would be interesting if you would try the 0.9.4 pre release available from github, instructions in this thread:
to see if this is already fixed in the pre release version. If it is still a problem, then it should be reported as an issue on github. This is why I have been pushing to restart development, it has been obvious that eventually new versions were going to break Fritzing if we couldn’t get development restarted. Luckily we have gotten development restarted (if slowly so far :slight_smile: ).
