ESP32-S3-DevKitC-1 N8R8
Previous work, similar parts
https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/hw-reference/esp32s3/user-guide-devkitc-1-v1.0.html
A google search of the form “fritzing part ESP32-S3-DevKitC”
indicates there is likely a part available here. Google is your friend …
Thank you for your prompt answer. There is only S2, not S3.
Then there likely currently isn’t one and you will need a custom part which will likely take a while.
I think I solve it. I used Edit Part and edited ESP32-S2.
I don’t know if it is correct, but I am uploading the part here, in case somebody needs it.
The development board is ESP32-S3-DevKitC-1-N8R8 v1.0
Marius
ESP32-S3-DevKitC-1-v1.fzpz (30.0 KB)
It looks fine. FritzingCheckPart.py doesn’t have any errors showing. Presumably one of the existing parts was close to what is needed.
