Hello experts,
since I’m used to the MB102 breadboard for a long time and using it for
the electronic lessons to 7th-11th graders I’d like to use fritzing now for
demonstrating good placement to a larger group of people.
However, I couldn’t manage to place NPN, LED and two resistors as I’m used to.
+++++++++++++++++++++R1+++++++++++++++++++++++++
hole
hole
R1
hole
LED+
LED- hole hole
C B E
R3 R3 hole hole
hole hole hole
R2 hole R2 wire
---------------------------------wire------
The sketch above is one part of a bistable FlipFlop, where the other part looks the same
and is on the left side (unshown here). R3 connects then to the other NPN-Base.
I like this placement of parts, because the three rows of holes below the NPN are comfortable for
cross-wiring other components e.g. capacitors for the astable multivibrator.
This sketch is very compact and is using only one wire for Emitter to GND.
However, I’m not able to use Fritzing to realize such a placement…
Does anybody know how i could resolve this feature ? Or is my wish impossible ?
Thanks in advance & best regards, Uli
