Arduino Uno (Rev3) for Top PCB Mount.
The PCB view of the Arduino Uno (Rev3) in Arduino Bin flipped upside down with the text flipped back so as to be readable. Other views haven’t changed
Protruding component position is outlined to provide indication of part contact.
Number in component outline is mm of protrusion of the component from the Uno PCB. Subtract the number from the USB (11mm), and it gives the air gap under the component.
Mounting holes not drilled. You have to place a hole from CORE bin on the hole outline circles if you want the holes drilled.
V2.0 - Arduino Uno (Rev3)-TopMount.fzpz (59.8 KB)
