4N25.fzpz (7.2 KB)
Optocoupler, Phototransistor Output, with Base Connection
Datasheet: http://www.vishay.com/docs/83725/4n25.pdf
4N25.fzpz (7.2 KB)
Again not bad, but a few problems:
bb again missing the layerId
pcb
the hole sizes are wrong, they should be 0.035in for an IC
yours are 0.027222 according to the gerber output.
fpz file
changed label from 4n25 to U to match other ICs
schematic
changed font to droid sans, and scaled it to make it smaller. In general schematic images want to be as small as possible to fit more on a page (and to match other parts). Again I also rescaled all the svgs to the standard scale as well
4N25_improved.fzpz (9.5 KB)
thank you for your instructions.
I’ve also improved my part and uploaded it to repository mentioned above if someone follows by the link. I hope the part is ok now.
Kindly regards
