Name of the Part
Buck Power Supply Module XL4005E1
Previous Work, Similar Parts
No prior Fritzing part found for the XL4005E1 Buck Converter Module.
Top View
The module includes:
- Dimensions: 43mm x 21mm x 14mm
- Connectors:
- Input: 2P through-hole screw terminals (VIN+, VIN−)
- Output: 2P through-hole screw terminals (VOUT+, VOUT−)
- Key Components:
- Adjustable trimmer potentiometer for voltage regulation.
- Heat sink over the XL4005E1 IC for heat dissipation.
- Large electrolytic capacitors for input and output filtering.
https://www.amazon.co.jp/-/en/Moechando-XL4005E1-Buck-Power-Module/dp/B08YNRSFXP
Refer to the XL4005E1 Datasheet.
Breakout board, sub-assembly, plug-in module (A)
Specifications
- Input Voltage Range: 5–32 V DC
- Output Voltage Range: 0.8–24 V DC (adjustable using a variable resistor).
- Maximum Output Current: 5A (with proper cooling).
- Efficiency: Up to 96%.
- Dimensions: 43mm x 21mm x 14mm (1.7 x 0.8 x 0.6 inches).
Breakout module with through-hole connections for VIN and VOUT terminals.
Additional Notes
x
