Hi there - I’m totally new to Fritzing and pretty new to electronics, so please forgive my ignorance.
How can I add a symbol that corresponds to +5V/VCC - similar to the standard symbol for ‘Grnd’ (a series of parallel lines, forming a simple triangle)? I’d like it so thatI can use this symbol where appropriate, without having to draw an explicit connection.
In the PCB view, why can’t I seen the Grnd/earth wiring? Is it because it forms the bulk of the PCB?
I don’t think those are dumb question… Everyone need some practice on fritzing to understand all the feature…
I’m not sure if I can help you out with this clearly… Let’s try…
Here is My answer,
There are VCC & GND symbols available in core parts schematic view. In the image I made two simple circuit with them.
Those are proper GND & VCC connection.
Hi Arnab - thanks fro your help. Thanks to your advice I was able to find +5V/VCC in the core parts section. I had been trying to use the search facility and neither ‘+5V’ nor ‘VCC’ return anything . As for my second point, I think I must’ve been having a ‘senior moment’ - I can see the ground wiring now!
