Has someone a SVG with embedded bitmaps for Fritzing?
I would like to see if the reported bug here is still present:
“try to create a new part, using “load view image” in the Parts Editor. The bitmap does appear, but once you save it as a new part and try to display the part in breadboard view, the image is no longer visible. This is a bug–the image should at least display in breadboard view.”
I think the only likely solution is to find a copy of
voltmeter2.svg.gz
from the google code svn repository. There used to be a copy on the github repo of Fritzing, but it was reputed to be corrupted and I don’t see it any more. A google search for voltmeter2.svg.gz and voltmeter2.svg don’t turn up a likely file. Without the failing svg file this is likely to be difficult to reproduce.
edit: That said, it looks like it is still a problem. This base part has no embedded images.
because it didn’t make it in to the breadboard svg on the exported part (even though it rendered in parts editor!) which I think is the bug that was accepted.
