# Stripboard / Veroboard does not work properly. :(
**URL:** <https://forum.fritzing.org/t/stripboard-veroboard-does-not-work-properly/5830>\
**Category:** parts help\
**Created:** [April 17, 2018, 12:37pm UTC](https://forum.fritzing.org/t/stripboard-veroboard-does-not-work-properly/5830 "2018-04-17T12:37:55Z")\
**Showing post:** 2
**Author:** ![sublimeartistry](https://forum.fritzing.org/user_avatar/forum.fritzing.org/sublimeartistry/32/2218_2.png) [@sublimeartistry](https://forum.fritzing.org/u/sublimeartistry)\
**Post date:** [April 17, 2018, 2:13pm UTC](https://forum.fritzing.org/t/stripboard-veroboard-does-not-work-properly/5830/2 "2018-04-17T14:13:30Z")
It helps to do a search for your problem before posting. All it took was a search for the word stripboard in the forum and the first result was [Stripboard / Veroboard extension not working correctly](https://forum.fritzing.org/t/stripboard-veroboard-extension-not-working-correctly/5024/3) and it has almost exactly the same title as yours so it is likely the forum suggested it as an answer when you started to type in your title.
_[View the full topic](https://forum.fritzing.org/t/stripboard-veroboard-does-not-work-properly/5830)._
