Smd sot-89 part?
There is a sot-89 part here:
although it has some issues that were never apparently corrected they may not be fatal. There is also a sot89 transistor (although pcb footprint looks incorrect for the am7135) in core parts:
The amc7135 appears to want vias (and thus presumably a bottom heatsink pad as well) which you would need to add to the sketch by pulling in a pad and vias (as Fritzing without a lot of work won’t mix through hole and SMD parts!)
