I have designed a PCB and all is good, but I need the same PCB but in reverse. It has a couple of ICs and various other components.
Hello, welcome…
Did you tried this button…?
By selecting “view from below” you can see from the bottom copper layer side.
If you are trying to get this reversed for export or etching purpose, fritzing will do it automatically.
Make sure, for single side PCB, you set the part layer “top” & trace layer “bottom”, or vice-versa…
Thank you for your reply.
It’s a double sided PCB. So, I’ll have to do as you suggest, move the parts onto the opposite sides from where they are now and redo some of the tracks.
