Requesting if this already exist
I don’t know if we already have it here; it’s my first week of using it, and it doesn’t seem to find these items (I’m looking for these parts here on the forum as I post this). Telling me where to download such parts can help me for my capstone. :folded_hands:
you can email me if you can(omwa4300@gmail.com)
MQ-7 Carbon Monoxide Sensor
DS18B20 Temperature Sensor
NEO-6M GPS Module
SIM800L GSM Module (2G)
Regulated DC Power Supply
Rechargeable Backup Battery
This looks problematic. Can you please link the data sheets here? Though I don’t think I’ll be able to develop 6 parts in a short time. Please sort the parts by priority.
Best regards, Harald!
Google is your friend… Several versions of both the DS18B20 and NEO-6M GPS parts, at least, exist.
Hello! I’m just going to make a spreadsheet so you can see my progress. So far, I only need four more components. The other two on my list already exist, but I’m still figuring out if I can use them for my project. Thank you for taking the time to help me and for noticing my message.
Spreadsheet Link(“PARTS NEEDED - Google Sheets”)
Uhh im down to 4 items and yeah i found what you’ve mentioned and im quite having a trouble finding
could you please send the parts as a screenshot? Your links lead to a shop where you’d need to log in.
For the power supply and the battery, is functionality or appearance more important to you?
A power supply can also be replaced by a general voltage source — it doesn’t matter whether the voltage comes from a power supply or a battery. That’s something the user can decide for themselves.
Regards, Harald!
I found the DS18B20 here — unless you’d like it in a different enclosure, in which case you can also use the LM35 for the sketch.
DS18B20 temperature.fzz (6.9 KB)
I took another look at your AI illustration — I’d leave out the power supply, i.e. the “Power System”, and simply connect to the circuit with 5V and 3.3V directly. There are also plenty of regulators available in Fritzing; if you type Regulator into the search, you’ll find lots of them.
Best regards, Harald.
Hello! I updated the spreadsheet with images.
For the Regulated DC Power Supply and the Rechargeable Backup Battery, I’m not sure which one is the correct component, so I included both for now.
Also, I don’t think I need the exact appearance of the components. I’m mainly concerned about their functionality and usability. As long as they work the same way in the project, I’m okay with using them even if they don’t look exactly the same.
As for the DS18B20, it seems that it’s not the component I’m looking for.
Thank you for your time and consideration, Jiro
Hi Jiro,
then you probably mean this component — functionally it’s the same. The downside, however, is that it doesn’t come in a weatherproof housing.
Here is the other housing type:
DS18B20 1-Wire Temperature Sensor.fzpz (7.0 KB)
