Hello!
Has someone allready desinged a part for transformer rm15 - 150.09-1: Printtrafo, 0,33 VA, 9 V, 36,7 mA, RM 15 mm bei reichelt elektronik
If possible, please attach - many thanks
Nice regards
Manfred
Hello!
Nice regards
Manfred
This should do what you need. It would be a good bet to print out the pcb footprint at 1:1 scale and compare it against a real part as this is from the datasheet. The holes are set for 0.1 header connectors (0.038in) but should clear the 0.6mm pins well enough as that is around 0.8mm.
transformer-gerth-150.12.2.fzpz (4.6 KB)
Many thanks!!!
Manfred
Dear Peter!
Do you have the transformer with one secondary winding, too?
I’m looking for gerth-150.xx-1 not 150.xx-2 (see https://cdn-reichelt.de/documents/datenblatt/C500/GERTH_DATA_SERIES-150.pdf)
Many thnaks
Nice ragards
Manfred
Dear Peter!
Many tanks for your support!
Kind regards
Manfred
