This should do the job. Because breadboard was around 1.5 megabytes (due to rendering the images as lines by the thousands!) I simplified breadboard a bit. PCB omits the connectors but is mostly there.
Given that there are eagle files available from Sparkkfun there is a converter (originally made by the Fritzing folks, but forked and improved by Adafruit, which is what I am using) called eagle2fritzing that generates much of the part which makes things a lot easier.
