Hi I’m wanting to find a fritzing part IC CA3130, where can I find this component please?
This should do what you need.
edit While fixing up a sketch using this part I discovered the schematic terminalId on pin 8 is incorrectly configured (and is offset from the grid slightly as a result.) I have replaced the current part with a corrected one, so if you have downloaded this part earlier please download it again and replace it with the new version.
CA3130.fzpz (5.7 KB)
Thankyou sir that will do the trick.
