Part request for ESP32-H2-DevKitM-1
ESP32-H2-DevKitM-1
Previous work, similar parts
There are some ESP32 symbols available but I could not find any for this 2 x 15 pin board.
take from Espressif SIte (link below).
https://docs.espressif.com/projects/esp-dev-kits/en/latest/esp32h2/esp32-h2-devkitm-1/user_guide.html#hardware-reference
While there are several 15pin ESP boards none appear to match this one so I will make one.
This part should do what you want. Note the current connector (normally a jumper) doesn’t appear on pcb as it is not accessible from there.
ESP32-H2-DevKitM-1.fzpz (28.6 KB)
Thank you so much Peter.
