# OCRA font not accepted
**URL:** <https://forum.fritzing.org/t/ocra-font-not-accepted/15052>\
**Category:** beginners\
**Created:** [January 29, 2022, 4:28pm UTC](https://forum.fritzing.org/t/ocra-font-not-accepted/15052 "2022-01-29T16:28:45Z")\
**Showing post:** 6
**Post date:** [January 29, 2022, 8:57pm UTC](https://forum.fritzing.org/t/ocra-font-not-accepted/15052/6 "2022-01-29T20:57:03Z")
There are dual font family definitions in this one:
 ![capture](https://forum.fritzing.org/uploads/default/original/2X/b/b2a1f78017a8cb3cd2fdbcef95b5df97d54f6f04.jpeg)
This is the svg displayed in Inkscape (you may want to consider changing to Inkscape, it is somewhat more Fritizing friendly.) Fritizing is likely complaining about the , monospace in the font family but I expect it will still work correctly using the OCRA font (although I don’t know for sure!) As well you have no connectors defined and lack a groupId. It is desirable the svg looks like this
 ![capture1](https://forum.fritzing.org/uploads/default/original/2X/e/edb01d455f18c9d4cea357cc8d090becd69fb9a6.jpeg)
These tutorials (which apply to the current version of Fritzing) may also be helpful.
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647):
_[View the full topic](https://forum.fritzing.org/t/ocra-font-not-accepted/15052)._
