Anyone found this part? Have searched for long now, but can’t seem to find this exact part…
This should do what you want. Note the mounting holes are only on silkscreen and by default will not be drilled. If you want mounting holes you need to drag a hole (from core parts/pcb/hole) in to the sketch and set the size appropriately.
lcd-1.3in-240-240-ips-st7789vw.fzpz (5.8 KB)
Thanks, that’s perfect!
