Need help creating a simple SVG file to Fritzing part
Need Help Creating Part
Hello everyone! I am currently working on a group project and am using Fritzing to display the wiring connections. I wanted to design the chassis we are using for our project as a part. I did my best to replicate the chassis design using Inkscape which is located here. I am not looking for perfection but instead of a uploading the SVG file as a PCB, I have been trying to upload the file as a part so i can show it with the rest of the components I am working on modeling for my project presentation and report. If someone is able to attempt creating a part for this, that would be extremely helpful for my project.
I don’t necessarily know if you are able to download the file, but if someone can provide instructions I can do my best to follow.
chassis
While I am not entirely clear on what you are trying to do, I think this may do what you want. First drag the breadboard image part in to the sketch
Then
click load image file and point it at your svg and you will have your svg in breadboard (which is the only sensible place it will go, although both other views will do the same thing.)
Yes! that works.
Thank you so much.
