# Looking for DM860A Stepper Motor Driver from Longs Motors Nema 23 Motor 1600 oz-in
**URL:** <https://forum.fritzing.org/t/looking-for-dm860a-stepper-motor-driver-from-longs-motors-nema-23-motor-1600-oz-in/4476>\
**Category:** parts submit\
**Created:** [September 9, 2017, 5:04pm UTC](https://forum.fritzing.org/t/looking-for-dm860a-stepper-motor-driver-from-longs-motors-nema-23-motor-1600-oz-in/4476 "2017-09-09T17:04:47Z")\
**Showing post:** 6
**Post date:** [September 11, 2017, 4:00am UTC](https://forum.fritzing.org/t/looking-for-dm860a-stepper-motor-driver-from-longs-motors-nema-23-motor-1600-oz-in/4476/6 "2017-09-11T04:00:27Z")
To modify parts you need to use an svg editor (the free one being Inkscape) to modify the svg files. Both it and parts creation have a fairly long learning curve though. Tutorials are here:
> [@A new part creation HowTo (long! So long it is in 2 posts)](http://forum.fritzing.org/t/a-new-part-creation-howto-long-so-long-it-is-in-2-posts/2238):
> (Edit: November 2016: This is an updated (and corrected) version of the original parts creation howto. This version corrects some suggestions (mostly saving Inkscape files as optimized svg which turns out to cause other problems) with the first version and expands the section on parts testing. While there doesn’t appear to be a lot of interest in this subject I’ll make at least this update so the information is as correct as I can get it.) This is a description of how I made the Valor PM6078-00…
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647/3):
> Fritzing Part Creation - Chapter3 - Inkscape Advanced Essentials Learning how to draw in Inkscape - more features. 0:00 Overview 0:16 Select object with cursor and XML Editor 3:34 Manipulate special PDF’s in Inkscape 4:33 XML Editor - Direct drawing manipulation 6:05 XML Editor - Making group, moving object, changing layer height 7:27 Cursor - Changing layer height 8:21 Ruler 9:07 Grids 9:28 Snap selection 10:16 Drawing origin
There is a stepper motor in core parts that will likely be close enough to what you have. The power supply I expect will be basically a box with two terminals and is easy enough to make. I’ll add the additional text in to the current part for the settings (I saw it, but was too lazy to add it.)
_[View the full topic](https://forum.fritzing.org/t/looking-for-dm860a-stepper-motor-driver-from-longs-motors-nema-23-motor-1600-oz-in/4476)._
