https://wiki.dfrobot.com/SKU_SEN0636_Gravity_UV_Index_240370_Sensor
I was wondering if anyone had this part on a fritzing library, if so could you provide me a file?
Thanks!
Thanks!
Doesn’t appear to be one. I will make one in a while.
This part should do what you want. Pcb view has been suppressed as not useful (to connect it to a pcb board use a 4 pin header to connect to the wires from the grove cable or a grove connector. )
dfr-sen0636.fzpz (12.2 KB)
