# Looking for 12 BH 7 elektron-tube (triode)
**URL:** <https://forum.fritzing.org/t/looking-for-12-bh-7-elektron-tube-triode/20043>\
**Category:** parts help\
**Created:** [July 24, 2023, 12:53pm UTC](https://forum.fritzing.org/t/looking-for-12-bh-7-elektron-tube-triode/20043 "2023-07-24T12:53:49Z")\
**Showing post:** 2
**Post date:** [July 24, 2023, 3:08pm UTC](https://forum.fritzing.org/t/looking-for-12-bh-7-elektron-tube-triode/20043/2 "2023-07-24T15:08:47Z")
Not sufficient information here to do anything useful. There are some pcb only tube sockets available here:
> [@Vacuum tube sockets Layout](https://forum.fritzing.org/t/vacuum-tube-sockets-layout/8657):
> Is there anyone out here on the Forum who already made PCB layouts for vacuum tube sockets? Looked into “core parts” and “connection” but could not find a clue there. I know I can spent time to make them myself but if someone has already done this……. I am looking for the 9 pins Noval socket and the 7 pins miniature socket. Then I can add these to my component library. Thanks in advance.
> [@12 pin tube socket layout](https://forum.fritzing.org/t/12-pin-tube-socket-layout/17510):
> Working on new fritzing PCB layout for 100W 2ch tube amp. Using 12 pin- GZC12-Y. I’ve laid it out in CAD and attached dimensioned jpeg. Be advised widely published 'net diagram of that model is incorrect (pin circle of 16mm) vs what I received (25mm). Latter is accurate- based on what I received & judging from pics of same products. Center .380"D circle ink only, please. Peter has been great help… kindly ask for his assistance adding these models to fritzing library. If need cartesian points f…
but they are not full parts (no breadboard or schematic.) To make a full part we would need a data sheet with the mechanical and schematic data for the tube you want (which doesn’t appear to be present in the link provided.)
_[View the full topic](https://forum.fritzing.org/t/looking-for-12-bh-7-elektron-tube-triode/20043)._
