LED Timing Light
I saw some strobe projects online using a camera flash, but I thought that they might not be readily availible to everyone.
What I’m trying to do is come up with a simple cheap circuit with easy to find parts so poeple can set their timing when trying to start their car using the Arduino ECU project - the whole project is about cheapness -. I found 1 circuit that doesn’t use many parts, so I’m testing that.
I have a simple LED timing light working, but it has problems and is rather weak. This one is cheap and only uses 11 easy to get parts, and if I can make it better I won’t worry about the Xenon strobe.
