I am newbee in fritzing. I want to draw a schematic that contains DSPIC33FJ128GP206A-I/PT-ND , and it has TQFP-64 package. I searched fritzing, but i did not find such package.
it exists in fritzing? and if it does not exists, what do I need to do ?
@mamech
The Atmel atmega2650 is a TQFP-64 footprint I believe. You may want to check that part as per your part specifications. If its not identical, you can easily modify the footprint of the ATMega2560 part using a vector graphics program such a inkscape. Search in the parts for ‘atmega’ that part should be towards the bottom.
