Hi can someone help me?
I have download a last realise of freatzing but wen the program start it fix at 14% of loading
Which Fritzing version and which operating system? First suggestion is that when it starts Fritzing makes a network connection to github to check for new parts updates. Fritzing appears to hang but if left alone for long enough (typically a minute or two for me on Windows, but I have heard of cases where it took 5 minutes or more) it will continue. If you interrupt it before it is finished, an internal database usually gets corrupted and some directories need to be removed (and reinstalling the software won’t help, because the reinstall does not delete the user directories.) Another thing to try is disable your antivirus while doing the install, some of the AV packages block Fritzing from installing.
