# How to convert from .fzp to .fzpz?
**URL:** <https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240>\
**Category:** parts help\
**Created:** [October 18, 2016, 6:24am UTC](https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240 "2016-10-18T06:24:35Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![ans2016](https://forum.fritzing.org/letter_avatar_proxy/v4/letter/a/e9bcb4/32.png) [@ans2016](https://forum.fritzing.org/u/ans2016)\
**Post date:** [October 18, 2016, 6:24am UTC](https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240/1 "2016-10-18T06:24:35Z")
</div>
Hello All. I downloaded a few parts from github, and they are in the .fzp format. To import parts in Fritzing, the required format is fzpz. How to convert from .fzp to .fzpz?
**Author:** ![steelgoose](https://forum.fritzing.org/user_avatar/forum.fritzing.org/steelgoose/32/332_2.png) [@steelgoose](https://forum.fritzing.org/u/steelgoose)\
**Post date:** [October 18, 2016, 12:24pm UTC](https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240/2 "2016-10-18T12:24:52Z")
</div>
You cannot convert a .fzp to .fzpz… the .fzp file is a xml file and just one of five files within the .fzpz. The .fzpz is a zip file with the extension .fzpz. To create a .fzpz, you would need to save all five files in a folder (part.fzp, breadboard.svg, icon.svg, pcb.svg, and schematic.svg), edit the file names with the proper prefix and zip them all up into a zip files with the extension .fzpz.
The file you are looking for may be in Fritzing… try a search, it may be in there somewhere…
**Post date:** [October 22, 2016, 4:04pm UTC](https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240/3 "2016-10-22T16:04:08Z")
</div>
Thanks. I have all the files you mentioned. Kindly indicate what you mean by ‘proper prefix’. Whichn package to use to zip them? WinZip, WinRAR or 7zip? Thanks for replying soon.
**Post date:** [October 22, 2016, 4:24pm UTC](https://forum.fritzing.org/t/how-to-convert-from-fzp-to-fzpz/2240/4 "2016-10-22T16:24:53Z")
</div>
You can unzip any .fzpz to see and copy the prefix for the five files. This link may also help describe what the prefix is for;
> [@Resistor-array?](http://forum.fritzing.org/t/resistor-array/2079/48):
> From the get-go, when I unziped it, I see 4 errors; only the .fzp file can have the prefix “part.”, the .fzp will be extracted to the folder /parts/user/. the breadboard .svg needs to have the prefix “svg.breadboard.”, as it is extracted to the folder /parts/svg/user/breadboard/. The same goes with the prefix on the other three “svg.icon.”, “svg.pcb.”, and “svg.schematic.”.
Make sure the file names in the .fzp are the same as .svg files.
I use 7zip, click the “Add to Archive”, it should default at "Archive Format: zip… if not, change it to .zip. In the archive combo box at the top, rename the file extension from .zip to .fzpz and click OK. It is just a .zip file with the .fzpz extension…
