# Help for schematic- and breadboardeditor
**URL:** <https://forum.fritzing.org/t/help-for-schematic-and-breadboardeditor/20873>\
**Category:** beginners\
**Created:** [October 16, 2023, 7:52pm UTC](https://forum.fritzing.org/t/help-for-schematic-and-breadboardeditor/20873 "2023-10-16T19:52:52Z")\
**Showing post:** 2
**Post date:** [October 16, 2023, 7:57pm UTC](https://forum.fritzing.org/t/help-for-schematic-and-breadboardeditor/20873/2 "2023-10-16T19:57:45Z")
Here are two tutorial sets that apply to current versions of Fritzing (may of the others are for older versions.) When you run in to problems (note I didn’t say “if” 🙂 ) feel free to ask. Parts making is complex and bites without warning.
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647):
I lately learned there aren’t links to the videos in Old\_Grey’s tutorial so you need to do a google search for the title and then they come up on YouTube.
Note even if you choose to use Old\_grey’s videos, downloading and using FritzingCheckPart.py will help you (or at least flag most of your errors.) It automatically corrects a number of svg editor features that Fritzing objects to.
_[View the full topic](https://forum.fritzing.org/t/help-for-schematic-and-breadboardeditor/20873)._
